Hello, I'm looking for buying a 93 KDX 250 for a very good price, problem: it lacks all parts of the ignition except the rotor ...
I have a full ignition of 200 KDX serie E , I wonder if it is compatible ?
Thank you
E serie Ignition on 250 KDX?
frenche200
i'm French and I don't speak English very well, so, please, excuse me :)
- Has thanked: 5 times
- Been thanked: 13 times
Re: E serie Ignition on 250 KDX?
so are you talking about the stator, or just the CDI/coil and associated wiring? I wouldn't imagine that the stator plate would mount up. Perhaps the individual stator/lighting coils on the 250 stator plate, but I kinda doubt it.
frenche200
Thank you for the answer! I was talking about about the stator, CDI/coil and associated wiring... Do you know if somme of these parts are the same on 250 KX ?
I doubt it, since the KX250 would not have had any lighting system. The MX bikes usually have a smaller flywheel diameter as well, so the stator plate is probably considerably different.
frenche200
Well, no solution except some 250 kdx parts ... Thank you very much
coltgti83
does the 89 kx cdi works on kdx250 94? i have a similar problem.. need to replace cdi box... if some one can help me an confirm this... thanks!
