Clutch doesnt dissengage
3j3j3j
Post by 3j3j3j »
I adjusted my clutch perch using the nickel method, but even when pulled all the way in, the rear wheel still moves. Is that normal?
chippy
Re: Clutch doesnt dissengage
Post by chippy »
If you have it off of the ground - yes. The KDX clutch tends to drag a bit, even when new. I run lighter oil or type F transmission fluid to try and minimize this.
3j3j3j
Post by 3j3j3j »
Does this go away as the clutxh wears?
It may to some extent, but all bike clutches have inherent drag and the rear wheel will move when on a stand with engine running. Even my GSXR does it.
3j3j3j
Post by 3j3j3j »
For part of my ride it was enough to make the engine die. That combined with my air and idle screws being off
