catch can modification? Anyone try this for crank ventline?
Posted: 05:47 pm Aug 02 2014
Ok so I noticed after riding up in pa my filter was pretty dang dirty. I thought well it was really dusty at the atv trail it musta just sucked a lot up with the riding. Well I go to take a look at my filter and its just dark and oily. Sure enough its got a nice coat of 10/30 on it. Now mind you I was doing some hill climbs and wheelie n it for some fun and of course bike was really never on quite level ground. So Im thinking that the crankcase vent which routes to the airbox is the culprit because my brute force does the same thing if I wheelie it a lot.
Now on the brute I installed a catch can from a kfx and it works great. Same thing with the brute it was puking oil into the airbox.
Pretty simple in design if you don't know what Im talking about. Its just a can that is designed to catch that oil and when the bike gets back to normal position it dumps the oil back into the crankcase. So no more ruined filters and you run less of a chance of running without oil. I mean really my filter despite the oil could of been used some more. I like to change em after a good long ride regardless.
Just a though I did a search and didn't show anything here and just wondered if someone else tackled this problem. Right now Im thinking of locating a can up behind the left radiator shroud. It can be done however Im just having a hard time finding a spot to locate it really.
Thanks in advance!
Thanks in advance!
