kdx 220 making rattling sound after crash
superman27e
Post by superman27e »
So, I was out riding and it started raining. My back tire is already bald as cheap (got a new one on the way) and then I hit a wet spot and the bike slipped out from under me. It was a small crash and it fell on the right side. I picked it up and tried to kick it over and it felt like the piston wouldn't move. The kick starter kept getting ....stuck? After a few tries, it finally breaks loose and it started with no problem. Only now it has a small rattling sound. The bike still runs fine and feels like the compression is fine too. I can't figure out where the rattling is coming from, though.
Sometimes it sounds like it's coming from the car/intake area, sometimes the engine, and sometimes the stator case.
Any ideas?
doctord23
Re: kdx 220 making rattling sound after crash
Post by doctord23 »
Check if your pipe is touching the frame.
The natural rattles will be amplified if that is the case.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
doctord23 wrote:Check if your pipe is touching the frame.
+1
A fall on the right side usually results in damage to the pipe mounts, brake pedal, or in bad cases the case/water pump. Check all the rubber pipe mounts, they routinely split at the rubber piece, make sure your header springs are still in place.
superman27e
Well I took the carb, intake and head off. Took the head off to check the piston. Anyways, it's not rattling anymore, so I don't know what it was, but oh well :p
Anyways, my piston is.....black, and the head is very brown. Just other thing to add to the to do list on this build. :roll:
diymirage
Post by diymirage »
lol, mine doesn't make any noise either when I pull the barrel off :lol:
but this support the idea that the pipe was misaligned
cornishwrecker220
Post by cornishwrecker220 »
I had a similar problem on my 220 last year when I too fell off on the R/H side...at tick over & low rpm I would hear an unusual noise from the R/H side...kinda werrrring sound, occasionally the kick start would jam too, so after removing the R/H casing it turned out the kick start spring & collar was slightly worn which made it jump out of its location hole & was rubbing on the clutch basket...I replaced the spring & nylon collar & the problems went away...collar & spring weren't expensive but when you add the cost of fresh gear oil, gaskets & coolant plus time to strip & rebuild it soon mounted up ! :sad:
