Bars
- diymirage
Re: Bars
why cant you use the bark busters ?
Re: Bars
cut the very end of the bar off and use a die grinder to smooth out the inside , If you dont have a die grinder use a drill bit .
- diymirage
Re: Bars
Your sure the throttle tube is open ended right ?
Re: Bars
All it takes to make it open ended is a hacksawdiymirage wrote:Your sure the throttle tube is open ended right ?
Some bars have plugs in the end, if you cant pull it out you may be able to drive it further in so the bolt will fit. Or cut the very end off like above. Or get new bars if you want! Having ridden with a set of oversize bars last weekend, I'm now shopping for my next set!
- KDXohio
Re: Bars
+1 on tusk bars
- Has thanked: 5 times
- Been thanked: 10 times
Bars
I have Tusk bars and they have many different bends available. I run the YZ/WR bend as they measured out the closest to the factory KDX bar.
- Gotanubike
Bars
I just orderd a MSR dominator YZ high bend bar not too long ago. Still waiting on them but they look good for the price
$40 with free shipping in the U.S
http://www.ebay.ca/itm/301000305455?ssP ... 1497.l2649
1990 KDX200
