Lost power and significant compression
C George
Post by C George »
My 220 , which I rebuilt over the winter with 180+ psi compression
lost a considerable amount of power the other night.
No real pull.
I just went and did a warm compression test and it's now at 150 +/-
after maybe 3-4 hours of riding.
Something must have let go like a ring.
I even pulled the silencer apart to see if some packing or core had come loose.
05 KDX-220R / 06 KDX-225R / Maxima 927 / Millenium Tech / Ron Black / PC , FMF / Many 220 engine mods / 40 + yrs. of riding dirt bikes 🀟🀟
Re: Lost power and significant compression
Is this the one with the super timing?
diymirage
Post by diymirage »
Jason wrote:Is this the one with the super timing?
:lol:
C George
Post by C George »
No ,,, i't's not funny . This bike has been running just a touch past the advanced mark.
I'll tear it apart today.
The Timing deal works just fine !! If you run the correct fuel.
C George
Post by C George »
:lol:
I don't see the humor myself. :sad:
diymirage
Post by diymirage »
C George wrote:
:lol:
if you happen to have kids you'll get it
you don't want to know how often ive told my kid that something isn't a good idea only to have him try it anyway and find out daddy was right
somehow, this feels the same way
Gotanubike
Post by Gotanubike »
I don't find it funny either. But post pics please! for science.
1990 KDX200
C George
Post by C George »
I've got my 220 apart now and even though I thought I thoroughly
flushed the cylinder with soap and water it looks like debris hit the
exhaust side of the piston / cylinder. :( :(
Strange how they look like small fractures on the piston ?
But I believe if you look at the rings closely in the picture , the edge is
scared up.
Not sure what I should do at this point ,,,,,,,, just mad at myself. :sad:
Bore and replate with new piston ?? The most expensive.
Slap new rings and gaskets in it and run it ?? lousy for this new a bike.
C George
Post by C George »
There's area's to the sides of the exhaust port where it looks like the
rings aren't even hitting.
I was not trying to be a smart ass. I was thinking you had two KDX's. Advanced timing might lead to advanced stress??
Again, I was not trying to be a smartass.
C George
Post by C George »
Jason wrote:I was not trying to be a smart ass. I was thinking you had two KDX's. Advanced timing might lead to advanced stress??
NO worry's ,,,,,, Yes , we do have two , my son's 200 and my 220.
I took some fine emery cloth , by hand , to the cylinder and the scratch's did knock
down quite a bit.
newbbewb
Post by newbbewb »
is that a wiseco piston, and is it still round?
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
C George
Post by C George »
newbbewb wrote:is that a wiseco piston, and is it still round?
Yes ,,, and as round as any piston is. Not to be a smart ass but all pistons cold are not round
and are tapered because they expand at different rates.
If I follow your thinking ,,,, was it too tight for the bore ?? ,,,, not by measuring the ring end gap
it wasn't.
Before pulling it apart if had no torque and seemed to rev easy which still has me dumbfounded.
I really hate to just rering it and put it back together.
Hard to take a picture but the exhaust side of the piston looks like it's got small hair line fractures
that you can feel with your finger nail. Nothing visible on the inside. ???
Postigo
Post by Postigo »
Check your air filter, It looks like something got inside your cylinder. As yo can see there is not seizure by heat expansion or timming. Looking at the photos I can distinguish the lubrication groves on the side of the piston and that is the first thing you loose during a seizure. Good luck
Gotanubike
Did you re-torque the head bolts after the first ride since rebuild? Did they feel loose coming off???
1990 KDX200
newbbewb
Post by newbbewb »
check the water pump?
C George
Post by C George »
newbbewb wrote:check the water pump?
Explain ? I did notice that the resevoir level was lower.
i don't see why the water pump would be at fault there. Obviously something got into the cylinder to nick the ring and cylinder. Either when it was put back together or through the air filter (check boot, carb and reeds). maybe the end gap was way too big (doubtful)
newbbewb
Post by newbbewb »
Water pump....as in did the engine get hot? Just throwing that out there. Ive seen a couple of water pump shafts break. Those bikes ran fine until it didnt. Doesnt explain the debris though
C George
Post by C George »
Gotanubike wrote:Did you re-torque the head bolts after the first ride since rebuild? Did they feel loose coming off???
No and they were torqued at 20lbs,,,,, factory spec 18 ,,,, yes , I should have retorqued.
