I made a leak down tester ($15
However, there was a bit of oil sloooowly squeezing out from a spot in the case.. behind the stator plate under the crank shaft. (see pic below)
This oil seems to have the consistency of transmission oil.. This would pretty much suggest that either my right crank seal is sucking oil, or the crankcase centre seal is bad - is that correct?
Could the oil that's coming out simply be pooled gas/oil mixture? My only obvious problem with that is that it seems far to thick to be gas/oil mix....unless somehow the gas left the mixture and just mostly 2 stroke oil remains.
What do you guys think..
