headlight
Oldfatnfast
headlight
Post by Oldfatnfast »
2001 220R My headlight and Tailights are very weak and surge low and lower, is this a sign of stator trouble or something else
diymirage
Re: headlight
Post by diymirage »
Perfectly normal
The stock lighting coil is only good for about 35 watts at peak
Your best bet is to run a LED taillight and rewind the coil
adam728
headlight
Post by adam728 »
Yup, at idle and low engine speeds there isn't enough output to properly power the lights, so they dim and surge. Once rpm is up a bit (maybe 3-4,000) then things should stay consistent brightness.
Oldfatnfast
Re: headlight
thanks for the replies, the light doesn't supply enough light at any rpm, I think the coil will need replacing, i like the LED taillight idea, I've found a higher output coil online, just hate to eat 100 bucks, of course I hate to eat a tree in the dark too, thanks fella's
diymirage
Re: headlight
Post by diymirage »
there is a thread on here somewhere about rewinding a lighting coil
pretty straight forward
if someone can pull it up for you I can send you the community coil of wire :grin:
B737driver
headlight
Post by B737driver »
Here's a link to the led taillight that I am running.
http://www.kdxrider.net/forums/viewtopi ... +taillight
There's also a very detailed post about how to rewind the coil. Think it was Slick_Nick
http://www.kdxrider.net/forums/viewtopi ... oil+rewind
yep
Live to Fly
Fly to Live
newbbewb
Re: headlight
Post by newbbewb »
diymirage wrote: if someone can pull it up for you I can send you the community coil of wire :grin:
\threadjack
oh ,realllyyy
/threadjack
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
diymirage
Re: headlight
Post by diymirage »
\threadjack
oh ,realllyyy
/threadjack
pretty sure it is floating around in my garage somewhere
Re: headlight
Yeah, rewind it yourself. 15$ in materials and about an hour of your time.
