Water Pump rebuild
Posted: 06:48 pm Jun 06 2014
Hey guys,
I have a 2004 KDX 200, and I am having a hard time finding any good information when I have questions, so I'm hoping you guys can help. About 2 months ago I rode into a puddle that was WAY to deep. It engulfed my bike, but as soon as I realized how deep it was I cut the bike off and jumped off to pull it out. I let the bike drain for a minute, and after 6 kicks or so it cranked back up. Shortly after, I stopped to eat lunch, and when I kicked the bike it cranked, but the kick starter didn't return up, and was making a horrible rattling sound. I was way back in the woods, and walking out would have taken hours, and with the sandy terrain would have been just about impossible. So I rode it all the way back with the kickstand tied up. When I got home, I did some research and assumed that the spring had broken. I also noticed my oil was milky. I knew that was from the water, so I drained the coolant and the oil, removed my exhaust, clutch cable, kick starter, and side cover. There was the broken spring. So, I ordered the spring, and the gaskets for the water pump and side cover. when the new spring arrived, and I attempted to install it, I found it to be much more difficult than just putting the springs post into the holes. When I tried sliding the spring onto the shaft, and inserting the spring post into the shaft, then turning the spring until the next post reached it's hole, I noticed the clutch was in the way. I tried finding info on removing the clutch, but I couldn't find anything thorough enough to make me confident in it being correct, so I took it to the dealership. I had them replace the kick starter spring for me, but when I got the call about the price, they also informed me that the water pump needed to be rebuilt, and my total would be $600.00, and the bulk of that was from man hours to re build the water pump. I asked them to replace only the spring, and I would try and do that pump my self. Now I can't find any information on the process, or any tools i may need to do this. I spoke to the mechanic that replaced my spring, and he was telling me that I would have to pull the shaft out and replace the bearings and impeller, the whole deal because it is grinding bad, and has a little play in it. I know that when a shaft has play, it usually means the bearings are bad, so I believe him. I don't know if I have to pull the clutch for this either, since it is so close to it, and I don't know what tools I will need for the job, but I have all the standard stuff, sockets, ect. I really don't want to spend the money paying someone else to do it, but I also don't want to cause a worse problem than what I already have by messing it up because I don't know what I'm doing. I appreciate your time if you have read this far, and I would be grateful to have some insight from someone with experience who may be able to help. Thank you.
