Is this baseline jetting safe to start with..??
Posted: 11:17 am May 27 2014
by Davenay67
I have done numerous maintenance items to the bike since I picked it up recently; new plug, new oil in crankcase, clean and oil the air filter, new gas/oil in the tank, chain lubed, etc.
The bike ran great when I got it but spooged very heavily. I stripped and cleaned the carbs, taking note of the jets in there. It had a #48 pilot and a #150 main. I have since fitted new Mikuni jets; #42 pilot and #155 main.
The bike has a Pro Circuit expansion pipe and Pro Circuit muffler with spark arrestor. Also Boyesen power reeds. Mix ratio is 40:1 on Amsoil interceptor.
Is this a safe starting point to begin jetting as per the guide..?? I tried to done some preliminary jetting in my driveway, but wasn't getting anywhere (turning the air screw wasn't having much affect). I suspect the bike really needs to be brought up to temp and I was getting aware of the noise and smoke I was making in out very quiet cul-de-sac..!!
Planning to take it out for a full day of riding, and do the jetting at the start of that day.
Am I good to go, or should I change any of the setup first..??
Thanks..!!
Dave. :)
Re: Is this baseline jetting safe to start with..??
Posted: 03:52 pm May 27 2014
by bufftester
Should be in the ballpark, but the only way to really tell is follow the jetting guide. BTW how did you fit Mikuni jets in a Kehein carb?
Posted: 05:26 pm May 27 2014
by Davenay67
bufftester wrote:Should be in the ballpark, but the only way to really tell is follow the jetting guide. BTW how did you fit Mikuni jets in a Kehein carb?
My bad, meant to say genuine Keihin jets. Was looking at my street bike in the garage yesterday, and had Mikuni on the brain. :roll:
Planning to follow the jetting guide, I just want to make sure I'm not running a bad setup that might harm the bike.
Thanks..!!
Posted: 08:30 pm May 27 2014
by Joshmcmillan
42/155 is a good start :)
Posted: 08:14 pm May 28 2014
by newbbewb
With a hammer, duh :kick:
