Front Wheel Compatible
eroknroll
Post by eroknroll »
I have a small crack on the rim of my front wheel on my 96. I found a local wheel cheap to replace it but it is a 93. Is the older front wheel compatible?
ICRage42
Post by ICRage42 »
Not entirely sure but I believe it does not. Due to the fact of the difference in hubs and trip meter. I have one for sale that will work for 95-06. With rotor and good bearings and spacers. I have it posted up in the for sale section. I can go a little lower for you.
http://www.kdxrider.net/forums/viewtopi ... 69&t=15573
You could as well swap the hubs to the other rim. That would require relacing and whatnot and also having to replace spokes due to being frozen(perhaps). With mine youd just have to pop a tube and tire on it and go really.
diymirage
Re: Front Wheel Compatible
Post by diymirage »
you can always have it welded and powdercoated aswell
by the time that is done it would be cheaper to get the one Don is selling
6 Riders
Post by 6 Riders »
Been using my 95 wheel on my 94, swap should work both ways......93/94 KDXs had the USD forks and swap onto the H series bikes just fine.
