Clutch adjustment ?
Posted: 09:57 am Apr 09 2014
by KDXrider32
I have my clutch adjusted where the pinion is at the 90 degree mark and the cable is tight at the lever ! If the cable is too tight will it cause my clutch to slip or just ruin it ?
Re: Clutch adjustment ?
Posted: 03:33 pm Apr 09 2014
by bufftester
There should be some play at the lever, I don't have my manual in front of me atm but IIRC its like 2 or 3 mm. Check your manual for proper adjustment. having it too tight can cause it to drag or slip under load
Posted: 08:06 pm Apr 09 2014
by Joshmcmillan
I think 1-2cm play in the clutch lever is ok. Better than having it tight.
Clutch adjustment ?
Posted: 10:28 pm Apr 09 2014
by Fitterman24
What's all this millimeter stuff ?
I use the good 'ol 1/8" to 3/16" of free play at the lever. I know, I know....but if an 'Merican nickel slips betwixt the lever and the perch, before pulling on the cable, it seems to suit my bikes just fine. I have been known to be half a moron, tho
