91 kx 125 forks to 04 kdx200
familyman690
Is this a big job,I have been reading the other posts but I don't see any 1991 kx125 forks being used.Does anyone know the dimensions of the kx fork tubes? should I look for later model usd fork?any input would be greatly appreciated.I can get a complete front end wheel brakes etc for a good deal.
Re: 91 kx 125 forks to 04 kdx200
You're better off looking for a newer front end as there were some notable improvements made between 91 and 99. But that said you can use the 91 forks. Process will be the same regardless of year/make
familyman690
Thankyou,tuff decision, great price....I was thinking the same 1991 -23yrs old,but they should make a big difference.
Special
For anyone that may still be interested they bolt right on I literally removed entire front end from a 91kx125 and installed on my 90kdx 200 but then decided to swap motors instead I have very little ride time on those forks and mine need rebuilt bad
- Has thanked: 49 times
- Been thanked: 15 times
Yes, 1991 is the last year for a bolt-on KX125 or KX250 triple clamp set. All KX forks will be taller and have the same geometry issues.
kdxEASYrider.net for non-shortened or non-pulled up to the sky fork.
