Clutch is driving me NUTS !!!!!! PLEASE HELP
Posted: 04:09 am Apr 04 2014
by KDXrider32
I have rebuit my bottom end , and had a mechanic who is a KTM certified rebuild it so I would know it was done right ! It runs great but when I pull in the clutch lever the rear wheel seems to not disengage when its on the stand the tire still spins like its in gear , while its on the stand is this normal ? The clutch arm is in the right position per the manual , it has be completely readjusted ,SPRINGS <PLATES<AND BASKET Iis in spec dont have anymore options ! :twisted:
Re: Clutch is driving me NUTS !!!!!! PLEASE HELP
Posted: 04:45 am Apr 04 2014
by adam728
Pretty normal. There's still oil between the plates wirling around transfering motion, so when the rear wheel is in the air there's very little resistance to stop it from turning.
Posted: 05:54 am Apr 04 2014
by Mayor Brap Brap
This drove me nuts as well, as every bike I've ever owned has been able to be pushed around the shop in a cold state with the clutch lever in. Neutral is the only way to go with this bike. Until you warm it up--then you can push it around with the clutch in.
Posted: 07:59 am Apr 04 2014
by Julien D
Perfectly normal.
Posted: 03:18 pm Apr 04 2014
by bufftester
Yep completely normal, KDXs always feel like they are dragging the clutch a little when pulled and in gear, on the stand it will spin all day.
