What size chain ?
What size chain ?
Hi, can anyone advise on the chain length I need for a 49/13 set up, seeing different lengths calculated in links, will a 110 link be ok or can I go shorter? Thanks in advance.
- Joshmcmillan
Re: What size chain ?
For 12/48 I got 120 and cut 10 links out. Also that was E-series. I'm not sure but swing arm lengths can vary. Better to be safe and get one too long than too short if you're not sure
07' CR450X (Main Bike)
91' CBR250RR
91' CBR250RR
What size chain ?
You should be able to run the STD chain length with those size sprockets although when I ran a 49 or 50t size rear sprocket it did rub on the chain guide so an extra few links wouldn't hurt as to shift the wheel back a little further....if I`m honest that gearing on the 220 is over kill unless you plan on riding Everest !
110 links is what I cut the chain on my H model 200. I am running 13/49 gearing. With that length it is actually a little long. 108 is too short.
