only ever seen the odd one on yahoo auctions japan!
but a browse came across this today on ebay uk, so had to buy it!...............
best regards
john
correct, twin lighting stator jobJason wrote:SR stator and flywheel?
I have just done a dc conversion using a trail tech reg/rec, battery, and currently have a 85w lighting stator, works great, just waiting for the new switch gear to arrive.TheJackRabbit wrote:do you have plans to rewind both lighting coils?
they have different part numbers.pumpguy wrote:Is the flywheel the same as used on the more common 1 lighting coil stator?
this is the only info I can find on the sr stator/flywheel etc, I would be surprised if they still made them, and at the cost new you could purchase another bike!Would you know the Kawasaki part numbers for this stator assembly and flywheel?
it is bent also though,Deseret Rider wrote:Seems like a hundred years ago I had a mid 70's KDX 175 with an 'open' ignition coil. I bought some motor winding wire from a local motor rewind shop and carefully rewound the coil. I lost count of the number of turns but just wrapped it until the space was used up--- The end result was a really hot spark---I guess I must have had more turns or maybe more turns of a slightly smaller size wire. What I am saying is that it really isn't a lot of trouble or expense to rewind that ignition coil yourself if everything else about the stator is to your liking?
If the later is true---go for it!
