Stock Headlight Aim???
morganid
Post by morganid »
Even though it's still winter in Idaho, I ride when I can. For now that means on the streets back and forth to college classes. But it gets dark early. I have discovered that my headlight is GREAT for checking the trees for monkeys and not so great at checking the road for ice patches. CAN THE STOCK HEADLIGHT OF A 2003 KDX 220 BE AIMED AT THE GROUND INSTEAD OF THE TREES? Seeing the road would be nice.
Thanks.
PS. Also why is there not a 220a forum in the Model Specific Forum section?
royadams
Re: Stock Headlight Aim???
Post by royadams »
The screw under the headlight is the adjuster. Loosen it it will lower the beam, tighten it will raise it.
spl383
Post by spl383 »
I bought a new longer screw and a stronger spring for mine.
TheJackRabbit
Post by TheJackRabbit »
there is no 220 section because the H series 200 and A series 220 are the same with the exception of the topend of the motor
I'm smarter than I act
Has thanked: 5 times
Been thanked: 12 times
Because it isn't any different than any other KDX manufactured since 1995?
morganid
Post by morganid »
TheJackRabbit wrote:there is no 220 section because the H series 200 and A series 220 are the same with the exception of the topend of the motor
Ah. I see. Thanks
morganid
Post by morganid »
royadams wrote:The screw under the headlight is the adjuster. Loosen it it will lower the beam, tighten it will raise it.
Awesome. I found the screw walking by my bike. When I get some time, I'll play with it.
THANKS! :grin:
morganid
Post by morganid »
Found the screw and adjusted it. The previous owner had it 100% screwed in :shock: I think that squashed my spring flat. I think I'll be getting another spring in the future.
