Has anybody ever tried one of these ?
It's a 3/16 to 1/4" spacer that increases the size of the resonator.
If I'm correct , I believe the resonator itself makes the exhaust
tract slightly longer at low rpm's.
I'd like to try one on the 200.
Resonator chamber spacer
- C George
Re: Resonator chamber spacer
If you mean resonator as in expansion chamber or header pipe, then yes you will notice a little more low-end grunt at the expense of a few hundred rpm's on top end pull. theres many threads already on here about it
- C George
The resonator chamber is on the left side of the engine cylinder. a rectangular box roughly 1.5 x 3.0"
The exhaust goes in there when the aux. ports are closed.
Yes, someone used to make one at some point, but I haven't seen or heard of one in a while. And I believe you are correct, should add low end power.
