Maxima 927 Picture " wow"
Posted: 02:47 pm Feb 02 2014
by C George
Here is the cylinder head that I just pulled off my 05 KDX-220.
I bought the bike " brand new " in 2009 and it's never been apart.
I've run Maxima 927 for it's entire life and am just amazed at how
clean this cylinder head is.
The ONLY reason this engine is coming apart is to replace the stock
piston with a Wiseco forged one.
Re: Maxima 927 Picture " wow"
Posted: 03:22 pm Feb 02 2014
by hbgod
Castor 927 is where its at man. thats all i use in all my 2 strokes.
Posted: 04:07 pm Feb 02 2014
by C George
I'll clean up the kips system while it's apart but that too is very clean and
moves easy. Actually I forgot that I took took one tension washer out to
make it slightly tighter. A little Shop Solv and let's go.
Posted: 11:06 pm Feb 02 2014
Thank you for the picture. I use it some.
Posted: 05:50 am Feb 03 2014
by C George
I'll probably send the head out to Ron Black before putting it back together.
Four months untill spring here :(
Posted: 09:16 pm Feb 03 2014
Hmm. Groundhog said six weeks.
Posted: 09:48 pm Feb 10 2014
by C George
hbgod wrote:Castor 927 is where its at man. thats all i use in all my 2 strokes.
I pulled the kips linkage cover off and there was virtually zero carbon or sludge build up.
Wiped the cover and bolted it back on.
Gotta love that smell ,,, something a modern four stroke rider will never experience.
Posted: 07:50 pm Feb 11 2014
by diymirage
Jason wrote:Hmm. Groundhog said six weeks.
Posted: 08:46 pm Feb 11 2014
Yeah, good frosting of snow here, closing schools today, threatening tomorrow and Thursday, just stupid..
Down here an inch or two = standstill
Posted: 05:14 am Feb 12 2014
by diymirage
anything under a foot is considered a dusting here
Posted: 09:23 am Feb 17 2014
by C George
OE Piston after five years of running Maxima 927.
Factory Knurls can be felt on the entire piston surface.
I actually sold it on E-bay ,,,,, somebody will get a lot more use out of it.
Posted: 05:53 pm Feb 18 2014
by C George
I just got my 220 head back today from RB . What a beautifull job !
Just no comparison to the local job I had done to the 200.
Turn around time was great as I mailed it out the 10th and got it back on the 18th.
Posted: 12:39 pm Feb 19 2014
by fuzzy
Curious, how much time do you spend 'lugging' or off-idle? As a percentage of your service?
Posted: 04:20 pm Feb 20 2014
by C George
fuzzy wrote:Curious, how much time do you spend 'lugging' or off-idle? As a percentage of your service?
I guess I don't follow your question completely but to answer what I believe your asking is this bike is aggressively
trail ridden in usually 3rd / 4th gear. 2nd in some tight stuff.
Why ? This bike only idles to warm up and lugs very seldom. Do I rev it out to 8000 on every shift ? NO
Does it look like it's running rich and has fuel stains ?? It's jetted good with a 35mm ,, just has the typical 220 sputter.
I'm crossing my fingers that with all the changes this winter , it will sputter less.
Posted: 04:23 pm Feb 20 2014
by C George
Great oil and custom blended fuel !!!! The only thing these bikes ever see.
Posted: 11:23 am Feb 21 2014
by fuzzy
You understood correctly. It's been my experience that castor blends will not look like this unless ridden a bit aggressively. A LOT aggressively if the jetting isn't right. Castor blends, if not pure castor, are the **** for WOT all the time applications. Looks like it works perfect for you, but also the reason when the 'oil question of the month' comes up I always recommend a full synthetic (non-'racing' even) for a trail bike. The superior film strength of the castor is mostly beneficial under extreme abuse. Castor certainly smells the best
If you can keep it running clean like this it would be hard to argue that castor isn't the best oil to use. Your engine looks nearly perfect inside!
