No idea what this is called ????
kdx2oo
Post by kdx2oo »
I have a 1990 kdx200 and their is a plastic piece that sits on the the frame under the seat that goes back to the air box ?? Anyways this piece is broken and i have no idea what this piece of plastic is called and i havent found any yet. so if you have any idea what this is it would be great.
:hmm:
Living the good life :)
6 Riders
Re: No idea what this is called ????
Post by 6 Riders »
The only thing that i can think of is the "snorkel, but that sits in the air box lid, there is also the tank damper, can't think of anything else that should be under there.
diymirage
Post by diymirage »
if it is the snorkel (or the airbox lid) the simplest solution would be to pitch it and rejet the bike :grin:
Has thanked: 5 times
Is it white and long? Someone may have installed a KX part there.
kdx2oo
Post by kdx2oo »
yes its white and long it has like a main body it splits into two... to go over the frame. whats its use and should i worry about getting a new one
Does it look similar to the clear piece in the pic below just behind the tank and above the airbox? If so it is a splash shield to keep muck from coming up around the rear shock into the airbox area. Post a pic, but there isn't an OEM piece that goes there IIRC
kdx2oo
Post by kdx2oo »
yeah from what i see in the picture and from your description thats what it is. Do you think i should look into getting a new one ?
If you have the stock airbox lid and snorkle on I wouldn't worry about it. even without the snorkle or lid I wouldn't worry about it as long as you're running with your side panels. My 220 didn't have that piece, but the KX did since the KX airbox was not designed for enduro conditions and is much more prone to getting crud up there.
kdx2oo
Post by kdx2oo »
Thank you for helping out :supz:
I thought you may have been talking about this piece on the bottom left. Sorry.
kdx2oo
Post by kdx2oo »
that might be it hard to tell in picture
I can't find that diagram, doesn't show that part for the 1990 E-series, and thats not an E-series frame, but that looks like a likely candidate
6 Riders
Post by 6 Riders »
not a stock part for your bike, I personally wouldn't worry about replacing it. Toss it out and ride!
kdx2oo
Post by kdx2oo »
Okay Thank you for all the help!
