KDX250 Starter Gear Assembly
Posted: 11:53 pm Nov 20 2013
I'm replacing the springs on the starter shaft. I know there's a steel tab that tucks under a keeper that's bolted onto the case housing. The big spring is held in place with on of it's tangs stuck into a hole drilled into the case. Is there a particular way to put the spring in? I ask since sometimes while I'm kicking over the bike, the gears won't catch. I can't find any noticable wear in this assembly.
