KDX250 Starter Gear Assembly
tlevta
Post by tlevta »
I'm replacing the springs on the starter shaft. I know there's a steel tab that tucks under a keeper that's bolted onto the case housing. The big spring is held in place with on of it's tangs stuck into a hole drilled into the case. Is there a particular way to put the spring in? I ask since sometimes while I'm kicking over the bike, the gears won't catch. I can't find any noticable wear in this assembly.
Re: KDX250 Starter Gear Assembly
The big spring should be installed so that the long leg that goes into the hole in the case is towards the case. Check a parts diagram like 1994 KDX250 Kickstarter
tlevta
Post by tlevta »
I've got bigger problems. Hole in case that holds the starter shaft in place is worn out. Yikes..
