Rad guard? a plus or minus?
Ryan
Post by Ryan »
hi, i can get some msr rad guards for $27. I was wondering if it is worth it. I already have slightly damaged radiators and do not want them to get worse. Also do they restric some of the airflow and become a problem or are they fine?? thanks.
They work well... and don't block enough air flow to matter....at least on mine.
OverTheHill
Post by OverTheHill »
Has anyone tried the Devol Extreme Radiator Guards? They are more expensive, around $70, and they mount to the frame for side impact.
Those do block air flow... at least that is what I have heard.
Ryan
Post by Ryan »
so you have msr rad guards and they work good? And if my riight rad is bashed in a little will theu still mount??
Mine are and work fine.
FLAKDX
Post by FLAKDX »
The Works Connection Rad braces are the best insurance for side impact. They do a good job of reinforcing the side of the rads. (most often damaged by tip over crashes). Unless you really have a problem with someone else roosting big ass rocks into the front of your rads the stock plastic gaurds are more than up to the task of protecting the frontal fins.
03 220R
Ryan
Post by Ryan »
how much are they new?? the msr ones?? and what rad fluid do you use at what ratio?? thanks
kelasaki
Post by kelasaki »
I'll second FLAKDX. I have more problems with dropping the bike in the rocks, than getting the front of the rads speared, so I have the WC braces and use the stock plastic louvers. They are solid.
KDXer
Post by KDXer »
Do a search its been covered many times already. Does that sound like a familiar response ?? :rolleyes: DRN ???
Just buy the premixed stuff. Just pour it in as is. I use Motul. If you overheat try Evans NG+ I beleive its called. Or theres also Water Wetter but not as good as Evans (or so I have read anyway).
NM_KDX200
Post by NM_KDX200 »
I have Devol guards on my KDX and WP on my KX. I kind of like the Devol better- have never noticed them blocking the airflow (that is, the radiator has only boiled once on me). In the woods, I'm thinking more of sticks and branches than roost.
1999 KDX 200
2001 KDX 220
2002 RM 134
2004 KX 125
Ryan
Post by Ryan »
how can you tell if the rad is boiling??
KDXer
Post by KDXer »
By the uncontrolable jet of steam and green stuff spewing out your overflow tube.
m0rie
Post by m0rie »
You'll hear it boiling when you come to a stop.
Ryan
Post by Ryan »
well do you guys know how much the msr guards are new, cause i mainly want them for slight protection and resale.
Dude... you put the cost in your original post! :shock:
KDXer
Post by KDXer »
:shock: Image :lol:
Ryan
Post by Ryan »
no those are how much i have to pay for used ones, im wondering how much they are used. :naughty:
Has thanked: 190 times
kdx220freak wrote:no those are how much i have to pay for used ones, im wondering how much they are used. :naughty:
For used, since you asked about used in this post, from the best I can tell, they are running around $27 used. :mrgreen: Just look on http://www.denniskirk.com, http://www.rockymountainmc.com or some place like that for the new price, if that is what you meant.
KDXer
Post by KDXer »
You'd best be asking the seller how much 'use' they have had if thats what you mean. :grin: :partyman:
EDIT.. OH I see what you mean.... I think... :?
