Kdx 200 just floods backfires and won't start
Kdx only
Post by Kdx only »
Just rebuilt top and bottom end bike ran great for two miles then flooded out changed plug and won't start since just keeps flooding backfires fouls plugs try's to run but just flooding help please I'm stressed
Have you checked your float? Jetting? Cleaned your carb?
Re: Kdx 200 just floods backfires and won't start
Sounds like a stuck float not letting the fuel valve seat. You did take out the carb, disassemble and clean it up in preparation for the rejetting you need to do after the overhaul, right?
Check the ignition timing.
KDXohio
Post by KDXohio »
What kind of shape are your reeds in?
jeeptech1
Post by jeeptech1 »
Paper towel jammed in reeds?
KDXohio
Post by KDXohio »
jeeptech1 wrote:Paper towel jammed in reeds?
Speaking out of experience? :shock:
Slick_Nick wrote:Check the ignition timing.
+1
Didn't think of it at the time, but with a bottom end rebuild you had the stator plates off likely,
jeeptech1
Post by jeeptech1 »
Lol, sadly yes. Hey everyone does dumb things right?(that's what I kept telling myself). It was pretty amazing it even ran, but that's a kdx for ya!
