It also over heats and starts pinging so I'm definitely thinking fuel starvation? I'm sitting here with my carb apart right now looking for anything that looks dirty and everything looks ok.
I tilted my carb sideways so that the float tang was barely touching the float pin, then measured with a caliper. Not exactly what the manual recommends, but it seems to have worked great for me. Good luck: once you get that bike jetted right its another world altogether. The Kdx had a really great, strong pull on the top end compared to most of the bikes I've ridden in the past. It's just got plenty of the right kind of power, everywhere you need it. To say I love my kdx is an understatement! It's as close to the perfect bike as I've seen-at least for general fun play riding and trails.ill bet for competition it was an awesome tool for a pro. Thanks to the unelected bureaucrats in the EPA, we'll never see a new Kdx again.Gotanubike wrote:Yeah the manual instructions for that are not so clear. remind me again, the measurement should be taken from the bowl mating surface and where?
edit: oh, 'mating surface to the top of the float'...K then that seems to be to spec.
They ordered me a tube based on the tire size 100/100-18 and it was $35...It better be the right size!Actionman wrote:Make sure you get the right size tube! I know a lot of people say " any 18 inch tube will do" but the previous owner of my bike had 6 rear flats over the course of a few months. The tube he had in it when I bought it (and all his other replacements) were tiny. I sanded down the rim smooth in the inner surface, put on a heavy duty rim strip, sanded sharp edges off any problematic nipples, put down a few layers of heavy duty duct tape- and I still got a flat last week while riding on a smooth flat road! My replacement tube is correctly sized for my tire, and its almost twice the size of the tricycle tubes he had in it. While it may not be a problem, I feel that the correctly sized tube is the way to go.
That would be a disaster.KDXsg wrote:could it also be not getting enough spark. Might be a fading stator coil (not lighting coil). My problem sound like yours and after much trouble shooting, found out that the leaking crankshaft oil seal is contaminating my stator and eventually shorted out. No high rev but low end is good.
Top end was just rebuilt with new left powervalveJulien D wrote:There is also the dreaded "Make sure your KIPS valves are working" comment. Just throwing it out there.
What was it doing before the top end was rebuilt? Are you sure that you aren't leaking air at the reed cage or at the intake boot?Top end was just rebuilt with new left powervalve
