UFO Front Fender Part Numbers??
Does anyone know what the UFO part numbers are for the green, wide, front fender and the green, narrow, front fender??
Thank you.
Thank you.
The only bikes listed on http://www.ufoplastic-usa.com are for the KX125/250, they don't specify the years if that matters or not. The part number listed are Front Fender: 12-111 (doesn't specify narrow/wide/etc.).
Color codes:
Green: 22
Neon Green: 36
White: 29
Black: 23
Color codes:
Green: 22
Neon Green: 36
White: 29
Black: 23
Thanks for the help. Their USA site isn't too helpful, and I can not figure out (even through an Italian - English online dictionary) what all the Italian words are on their site on the PDF files showing various years. Maybe between this site and the Italian site, I can put it together.
Thanks, karbon_dunn!
- KDXer
Thanks, KAY DEE EXER. I will take a look at your pictures. Could you check the underside for a part number? PLEEEEEEASE?
Slacker.
- KDXer
Darn batcave.
Thanks, everyone. I got the correct part number for the parafango anteriore. OOPS! I meant front fender.
SUPER terriffic, KAY DEE EXER!
I had to look at that two times to catch it.
- quailchaser
So....What are the two different UFO part numbers?Jason wrote:Thanks, everyone. I got the correct part number for the parafango anteriore. OOPS! I meant front fender.
Narrow=?
Fat=?
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
KA02755021 is the lime green, narrow, front fender.
KA02700021 is the lime green, wider, front fender.
To me, "narrow" means 1995 and newer KDX style. My C and E models came with a wider fender than the 1995 and newer models.
