Kaw Bayou 220 advice
turtle
Post by turtle »
we have a 1994 Kawasaki bayou that was given to us. It hasn't run in about eight years. we changed the fluids and everything just getting it ready to try and start. My biggest concern all long has been the carburetor because even though the tank is empty I am Not sure the carb was drained before the machine sat.
we have hit an obstacle ahead of that though. We put a new battery in it and I was going to turn the key on and maybe spin the engine over, but it is dead as a doornail. No lights, no power to anything. I'm not very good with electrical. I have a couple of ideas of what to check on it, but what I really need is a good logical troubleshooting procedure. anyone have any advice for what they would do in this situation? Thanks!
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Doc76
Post by Doc76 »
First thing I'd do is bypass the kill switch just to check if that doesn't get you juice break out the ohm meter and start checking everything. I know it's time consuming and it sucks but it is more than likely something simple. Good luck
If I remember right they have a key switch and a kill switch. It might be worth checking both of them to see if they are working. Like said before it is probably something simple. If it does have a key switch and everything is dead (and the battery is charged) then I would look at that first.
turtle
Post by turtle »
Thanks guys. We'll see what we can do!
Bill
Central IL
2004 KDX220R
ICRage42
Post by ICRage42 »
+1 on the battery charged. Most of the bike batteries you have to trickle charge them overnight before they have a full charge. If you didnt do this youd have no lights etc. Kinda ruling out all for you not trying to be ignorant. Dont be fooled as well. Ive bought several batteries and have atleast 2 out of 9 that were bad. Granted from advance and autozone however the other ones bought there Im going on 4 years now on couple of them.
Make sure your positive and negative leads to battery are ok and not corroded up. Even tho you hooked them up they still cannot be making a good contact. Wire can also corrode up the wire under the insulation creating a barrier between the copper and end for battery. The end could look just fine too. Take a good look at them. I had this on my quad and it drove me nuts for about a month. Tore everything apart tons only to find later I wasnt even making contact to battery on positive lead. Once I changed the ends started right up.
Look at your wiring harness and see if you have any fuzes inline. I have one on my positive that went on me a couple of times. Pinched wire between plastic and frame. I carry a couple spare in a baggie taped and ziptied to almost where the fuze is.
Once you eliminate these steps and if still not moving I would look at the key switch itself. See if you cant get a wiring diagram for the quad and test the leads. You can pick up a cheap tester to see if you got juice going through the switch. Could have a bad switch. With the diagram you would be able to bypass the switch.
I dont think killswitch plays a factor here unless pushed in or damaged but you still should be able to atleast turn key on and have headlight. Killswitch on like mine just stalls the bike but my headlight stays on. Cant remember for bayou. Been a long while lol.
Most quads have similar setups and this is just a general looksee but should be able to get you atleast with power.
If your unaware if bottom of carb was cleaned and whatnot just dont run the bike and pop the float bowl off and clean er out before trying to crank er up. Atleast this way you can check the float and whatnot while your doing this put a little gas in tank and let it run through and out carb (grab a jar to catch gas). Check fuel filter if any and make sure you have gas flowing and you can gently manipulate the float up and down and it shuts off gas and lets it flow. Be careful of the gasket could try to reuse however Im sure you can order one or find one. Hopefully the bike was ran empty.
I have confidence youll get it going if nothing major is wrong in engine. Really just sounds like you have something small goofing with ya. Take the plastics off and make sure you have good connections and grounds. A little time saves a huge headaches. Trust me I rewired my bike only to find the corroded wire and end. I did look good at it just not good enough. Taking the plastics off just makes everything a helluva lot easier and if you get er running you can go over everything with ease just cant ride it till ya get the seat back on.
This is a general quad fixer but most quads are same in concept just a little different in design.
If its the switch I guess Ill have to show you how to hotwire a quad. In my case a toggle switch hahahahaa :lol:
Did the bike sit outside for some time?
turtle
Post by turtle »
Thanks for taking the time to share your exeriences, IC. Lots of good ideas to follow up on.
Bill
Central IL
2004 KDX220R
