My friend has a 99 Honda cr 250 with a bad engine and is parting out the rest of the bike. I can grab some parts from him, dirt cheap, for my planned suspension upgrade. I'm having trouble locating information if this will work. I've stumbled upon this post.
KDX fork conversion using Honda CR forks and KX triple tree
http://kdxrider.net/forums/viewtopic.php?f=104&t=2557
Can I use the triple tree, brakes and wheel?
Honda Cr 250 forks?
- rbates9
Honda Cr 250 forks?
It looks like the post you listed will have the info you need to get the job done. But as far as using the CR triples it will be trial and error. If you end up needing a KX triple Scotts has a lower on clearance for $50. http://www.scottsperformance.com/groupi ... &Groups=25 . If you can get the forks and all the required parts cheap enough then anything can be made to work.
Shonuff
Re: Honda Cr 250 forks?
Thank you for the reply. I'm gonna strip the Honda of its front end suspension this week and see what works and doesn't work with my 89 that's just laying around. I'll update this thread when I get into it.
- fuzzy
I think those are twin chamber showas, which could be an excellent choice!
- ICRage42
Honda Cr 250 forks?
any updates ? Kinda want to go this route myself possibly.
- Tyl3r
I found a CR 250 front end on C-list for a good price... wanted to know what the verdict was for using Honda forks? I don't know what to do about stem and clamps? Can I use my kdx stem with the CR clamps (press right in place of the honda stem on the honda clamps? knurl the kdx stem to be pressed into honda clamps?)? I can figure everything else out as I go, I just want to know what I'd have to do about the frame/stem/clamps connection.
- gsa102
Not every swap has been done, so it may be up to you to find out what works. Instead of knurling mine, I used a retaining compound from permatex for the .015" clearance.
What year? The conventionals on the 87 cr250 are considered to be some of the best off-road forks ever. The current CRF250X (USD) units are very good. Most MX forks require revalving for off road, and not all are good even after that is done. I really like my DRZ forks (conv). My WR450 forks (usd) are really sketchy at times.
IMO, USD does not always equal better.
96 KDX 200, 09 YZ 250
Goofaroo
I agree completely. I found a nice 88 model CR250 for sale locally that would make a killer woods bike with a few mods but I can't figure out a solution for wider ratio gearing.What year? The conventionals on the 87 cr250 are considered to be some of the best off-road forks ever. The current CRF250X (USD) units are very good. Most MX forks require revalving for off road, and not all are good even after that is done. I really like my DRZ forks (conv). My WR450 forks (usd) are really sketchy at times.
There are probably some out there that are set up fairly nice but I have never ridden a bike with an USD fork that felt right to me. After spending a lot of time and money on the forks on my KTM300EXC I finally gave up and sold the bike. My XR350 and KDX200 make me feel right at home and I can ride longer without fatigue than I can with the USD forks. Even softly sprung and lightly dampened the USDs just feel harsh because of the extra rigidity. I'm not fond of aluminum frames either.
