Seriously...I'm not an engineer, but I am a tightwad. Unfortunately, I didn't stay at a Holiday Inn Express last night. Have been giving this a lot of thought (at least what constitutes a lot of thought on my part). What are the possibilities of building a Dynaring/EXP 2.0 type auto clutch. If you made it a steel plate, you wouldn't have to worry about trying to bond friction material to it (plus may work as a flywheel weight, depending). Use XR frictions to help compensate for lost surface area. The majority of the rest of the internals are available separately from Rekluse. Yes, it would be a lot of work. Yes if it didn't work, you'd be out some cash. Yes if it grenaded, you'd be in a world of hurt. But if it did work...BAZINGA! If you have engineering experience, please chime in. If you don't, chime in, too. That way I'm not the only jackwagon in this post...and go!
