125 or 250 frame?
Posted: 02:13 am Jan 25 2013
by jbg_3d
What's better to start with? Is there much difference. The more I look into all this and the amount of $$$ I may be putting into a KDX build, I'm thinking of going the hybrid route.
Re: 125 or 250 frame?
Posted: 06:19 am Jan 25 2013
by Tedh98
You could use either, but the 125 is going to be an easier build related to the pipe. The cradle on a 250 frame is larger to accommodate the bigger engine. When the KDX engine is in the 250 frame, there is a large gap between the engine and the down tubes. You'll would need to cut the pipe and add an extension. When I mocked up a 250 frame once there was a ton of room, it looked a little funny compared to the same engine in the 125 frame.
125 or 250 frame?
Posted: 10:57 am Jan 25 2013
by scheckaet
+ the 250 is a bit heavier than the 125
Posted: 11:05 am Jan 25 2013
by doctord23
Use a 125 frame.
As Ted said, the 250 frame will cause pipe fit-up problems.
Posted: 05:13 pm Jan 25 2013
by bufftester
125 frame is the way to go, my next one will be an 04-05 (currently building one on a 01 125). You can find 99-05 125 parts and bikes pretty cheap. The Hybrid forum has every answer you need, backed by lots of firsthand experience!
Posted: 08:44 pm Jan 28 2013
by jbg_3d
I am currently in search of a 125 frame for myself, but that may wait for another winter. My buddy is going ahead with his 250 frame build, we'll post up build pics as things progress.
125 or 250 frame?
Posted: 11:56 pm Feb 28 2013
by tlevta
Will my KDX250 motor have header pipe issues in a 125, or should I just get a KX250 frame?
125 or 250 frame?
Posted: 12:48 am Mar 01 2013
by SS109
For KDX200/220 hybrids use a KX125 frame.
For KDX250 hybrids use a KX250 frame.
125 or 250 frame?
Posted: 01:59 am Mar 03 2013
by JTSDAD
tlevta wrote:Will my KDX250 motor have header pipe issues in a 125, or should I just get a KX250 frame?
I have done a few kdx250 conversions and I use kx250 frames because the frame mounts line up like it was made for it. I have been using header pipes that are made for the year of kx250 that the frame was from. On my first build I noticed that the kdx pipe would work bu you have to rework pipe mounts and make changes on the silencer to make it fit and mount up. If you use the pipe and silencer to match the frame it is a bolt on deal.
125 or 250 frame?
Posted: 12:41 am Mar 19 2013
by OsoBlanco
When you say "KDX250" conversion are you talking about a 200/220 into a KX 250 or a 250 KDX motor into a KX250? I just started a 2001 KDX 220 into a 1998 KX 250 so any info is appreciated.
125 or 250 frame?
Posted: 04:01 am Mar 19 2013
by kdxtreme
When you say "KDX250" conversion are you talking about a 200/220 into a KX 250 or a KDX motor into a KX250? I just started a 2001 KDX 220 into a 1998 KX 250 so any info is appreciated.
He's talking about a kdx 250 conversion not the 200/220.
