1. Revolved fronts forks with heavier springs
2. 03 KDX 200 FMF Gnarly pipe - no mods needed
3. 03-05 KX 250 FMF Powercore muffler - nearly a straight fit. Note to any potential builders - I started with a KDX 200 FMF muffler and when we tried to heat and bend it kinked so had to sell it and got the KX one
4. Cut and rewelded engine mounts and muffler mounts so I can use standard KX 125 rubber muffler mounts. No issues with tank clearance and have had the front head stay mount milled off. Machined swing arm to fit. Cut and shut standard 125 head stay to fit.
5. Have a Boyseen rad valve and have a aluminum ring made and loctited to the carb to use the standard 125 air box boot
6. 08 KXF450 radiator shrouds with slight mods to radiator support brackets
7. Revalved rear shock with heavier spring
8. Replaced all bearings, chain, sprockets etc
Will post some pics shortly. This project is on another site. Has been a really straight forward job to date, apart from the muffler f@&k up no other issues. Total cost is 3K NZD so a bit over 2K USD. Max fun factor for a cheap outlay.
