Shift Lever Adjustment
I have a 2005 KDX 200, is there any possible way to adjust the height of the stock shift lever.
- diymirage
Re: Shift Lever Adjustment
undo the pinch bolt, pull it off of the shaft, rotate it to where you want it and put the bolt back in
thats all ther is too it
I believe I had to file a little bit of the square area off of the outside of the lever where it attatches to the shaft to get my lever where it felt good, will rub on the case if you drop it to low and don't remove some material.
skippypinecone wrote:I believe I had to file a little bit of the square area off of the outside of the lever where it attatches to the shaft to get my lever where it felt good, will rub on the case if you drop it to low and don't remove some material.
Same here.
