Engine/ gearbox and drive ratios
Posted: 07:38 pm Nov 26 2012
I've got a 13/47 sprocket ratio on a '03 200. It's street legal and I am wondering if it would pull 75 MPH on pavement at a reasonable rpm----I don't want to have it screaming--So I'm wondering how to calculate ratio's----First, I'd need to know the basic engine to 6th gear output ratio-----and then , from there, to know what effect a 14 or 15 tooth counter shaft sprocket would produce. What I'd like to do is when I get to the dirt to be able so simply exchange the Countershaft sprocket and go trailing. For that simplicity I'd prefer not to mess with the rear sprocket at all-------and finally, I'd like to know where the break off point is on the chain length I.E. can I run a 14 or a 15 without adding a link? How to achieve my goals----Idea's and advise appreciated.
