Jason wrote:When you get the collar off, note that it has a groove on the inside where the o-rings go. Make sure you put the new one on in the correct direction.
Thanks again, will do
Here's my list
Part Number: 13156-1269 Description: LEVER-CHANGE,PEDAL Price: $35.59
Part Number: 13161-1170 Description: LEVER-COMP-CHANGE SHAft Price: $28.92
Part Number: 92049-1366 Description: SEAL-OIL,MHSD8X18X10J Price: $7.78
Part Number: 92049-1359 Description: SEAL-OIL Price: $3.94
Part Number: 92051-005 Description: OIL SEAL,TB13225.5 Price: $3.39
Part Number: 92055-035 Description: "O" RING Price: $1.92 X 2
Part Number: 601B6204 Description: BEARING BALL #6204 Price: $8.17
Part Number: 92045-1304 Description: BEARING-BALL Price: $4.79
Part Number: 92045-1305 Description: BEARING-BALL Price: $5.02
Part Number: 92081-1926 Description: SPRING,KICKSTARTER Price: $6.77
Part Number: 482K4000 Description: CIRCLIP SELD BEM FIT Price: $0.57
Part Number: 11009-1996 Description: GASKET,CLUTCH COVER Price: $8.08
Part Number: 13165-1119 Description: PAWL,CHANGE LEVER Price: $5.16
Part Number: 315G1200 Description: NUT Price: $0.54
Edit: I found a place that sells the moose oils eal kit. Wonder if it includes the seal for the water pump?
http://www.monkeybuttparts.com/pk4/stor ... oduct=2000
