Jet Reamers, worthwhile?
Posted: 07:31 pm Oct 05 2012
by 99sr220
Anybody using jet reamers? I was thinking about getting something like this http://classicandspeedparts.com/index.p ... &Itemid=53
I would also get a jet guarge
Jets for me are close to $10 ea, plus the ride across town to pick them up. More available and much cheaper are smaller jets for PWK28, so it should be possible to ream these.
Long term I may save money, but the most important thing is the convenience.
Any thoughts?
Posted: 10:09 pm Oct 05 2012
by rbates9
PWK jets should be all the same from one carb to another, just different sizes. I would avoid using a ream to adjust your jets because you will never really know what you have if you need to replace them down the road.
Posted: 11:05 pm Oct 05 2012
by SS109
rbates9 wrote:PWK jets should be all the same from one carb to another, just different sizes. I would avoid using a ream to adjust your jets because you will never really know what you have if you need to replace them down the road.
I agree 100%! You only need a few jets anyways. Order them online cheaper than you buy them local.
Re: Jet Reamers, worthwhile?
Posted: 07:37 am Oct 06 2012
by diymirage
if jets are 10 dollars, and this set is 60 that means you can buy 6 jets (plus what you allready have) or buy the reamer and use the ones that are in the carb right now
to me, it seems better to buy the 6 jets and know where you are
besides, what if you are to rich?
then you still need to buy smaller jets
(on a side note, a set of 10 main jets runs 28.95 on ebay)
Posted: 09:47 am Oct 06 2012
by Julien D
Not sure how large the PWK28 jets go in size, but they are the same jets. If you can get them in the size you need, they'll work. You can use a reamer as a last resort. No, it will not be as accurate as a purchased jet, and may have different flow characteristics. But the exact size of the jet won't matter so much as it being the exact amount of flow to get you jetted correctly.
Posted: 09:38 pm Oct 07 2012
by 99sr220
The PWK28 jets stop at around 140 I think, they certainly don't go up to 150+. The biggest problem is finding the larger jets, I rode across the city the other day only to find the shop was out of stock.
Nonetheless I won't be getting the reamers, as I'd also want guages, which makes it too expensive. I suppose the 150 - 160 jetting kit is the one to buy? Any suggestions for idle jets? These have to be bought online, sent to a freind who then sends them here to me in Thailand. It makes sense to have several things sent at once, so it's best for me to get a few.
Posted: 10:22 pm Oct 07 2012
by rbates9
Pilot jets from 38-45 should do what you need. 38,40,42,45, and might just as well get a new 48 if it is that big of a problem to get them.
Posted: 09:39 am Oct 13 2012
by 99sr220
Thanks for the help, I've been able to get pilot jets up to 45 for less than $2, hopefully I can get the main jets also.
