Tips for fork seal replacement
Dekon
Post by Dekon »
Anyone have any tips for doing the fork seals on an E series?
david
Country: UNITED STATES
Post by david »
Nothing special. Typical standard forks. It helps if you have a parts washer and air tools. A 3/8 impact on the lower bolt that holds it all together makes easy work of it.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
gsa102
Post by gsa102 »
USE WITH CAUTION!
A trick I learned for conventional forks is to remove the seal retainer clip, then put compressed air into the fork through the bleeder hole to push the seal out. Then you don't have to disassemble them. If the seals stick then pour hot water over the seals to soften the rubber and try again.
Hold a rag over the seal so oil does not go flying when they come out.
I was going to replace the fork seals on an 81 MX 100, but could not disassemble them and they wouldn't come out with air pressure. So I used a thin plastic seal cleaner tool to clean the seals, and filled with fresh oil. No more leaks. I was amazed!
96 KDX 200, 09 YZ 250
Dekon
Re: Tips for fork seal replacement
Post by Dekon »
Great tip. You mean the bleeder on the top of the fork tube and not the drain on the bottom, correct?
Has thanked: 6 times
It is 10mm or 14mm on the base valve (compression adjuster assembly).
david
Post by david »
If that is all you want to do is replace the seals and not clean them out, I have used two of those very sharp sheet rock screws. Tap them into the seal with a hammer then screw them in a little. Use some side cutters or pliers to grip the screw and lift the seal out of its seat.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Dekon
Post by Dekon »
Yup, all I want to do is replace the fork seals and oil.
You won't be able to clean out all the gunk and residue if you don't separate the tubes.
Dekon
Post by Dekon »
Jason wrote:You won't be able to clean out all the gunk and residue if you don't separate the tubes.
Crap!
david
Post by david »
It's not that hard.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
RailwayRog
Post by RailwayRog »
gsa102 wrote:USE WITH CAUTION!
Okay I did this and it worked, great.
But now how do I get the correct amount of oil back in the fork tube?
I lost oil from the leaking seal and using this method.
mud99
Post by mud99 »
Remove top cap, dump out oil by cycling the shock upside down over a bucket, remove spring.
Use air impact tool to loosen bolt on bottom of shock using short high speed bursts.
Remove dust seal from fork body. Remove circlip. Hammer fork tubes from fork body by forcefully extending shocks with a slide hammer type of motion.
Everything should be obvious at that point.
mud99
Post by mud99 »
As far as the oil, you need a fork oil tool.
Steve_K
Post by Steve_K »
A good tip when taking seals out. Is to heat the outer tubes up so the seals come out easier.
mud99 wrote:As far as the oil, you need a fork oil tool.
no you don't.
need a syringe, some tubing and a straw...
