I broke KIPS
terminatr
I broke KIPS
Post by terminatr »
I got the replated cylinder and new piston back on. And I was trying to put on the
advancer shaft lever. I turned the advancer shaft gently with a wrench, to see
how far it will turn. As I was turning that shaft, I heard a pop behind the engine cover.
And now the shaft has no spring tension. What did I mess up? :sad: :cry:
Btw, the advancer shaft is the one with the left-handed thread.
2001 KDX 220 R
2001 KDX220
Has thanked: 5 times
I broke KIPS
You didn't support the shaft, did ya? You broke the pin that engages the governor down inside the case most likely.
I broke KIPS
Why?
Sometimes i wonder why i post the same stuff over and over :roll:
http://www.kdxrider.net/forums/viewtopi ... 57#p117919
lucky 4 u the part cost only 5 bux.
diymirage
I broke KIPS
Post by diymirage »
scheckaet wrote: lucky 4 u the part cost only 5 bux.
and another $10.95 for the inner clutch cover gasket
oh, and 5 dollars worth of ATF oil ;)
Has thanked: 6 times
I broke KIPS
OOOPS. It sounds like you failed to support it with a wrench.
terminatr
I broke KIPS
Post by terminatr »
It didn't break ! :boogie:
The pin jumped out of the groove. But didn't break.
I reused the side cover gasket. But I did have to buy 1 qt of ATF ($4 cheap stuff) and
suffer two more hours in the very hot garage. :boogie:
Just finished my first top end rebuild. It's definitely not as fast and easy as I was
beliveing.
2001 KDX220
I broke KIPS
You got very lucky! I hope you remember this when you do your next servicinging on the KIPS.
I broke KIPS
your are not out of the woods yet. I strongly suggest you'd replace that, it is probably bent / weakened and it WILL fail, maybe not on the 1st ride but it will. Ask me how I know.
you've been forewarned...
terminatr
I broke KIPS
Post by terminatr »
Ok thanks. I'll replace that pin soon. Opening the side cover wasn't as terrifying as I thought it would be.
2001 KDX220
Re: I broke KIPS
Next time, lay the bike on its side, then you won't have to replace the oil. Yes, that is a bad plan for a number of reasons..but you can easily save the oil that way.
I don't think you can twist the governor rod past its operating limit (have it 'pop out') without bending the pin.
A general rule to keep in mind when wrenching on stuff: Don't force (or even move) 'stuff' backwards.
Think of the forces applied TO the governor shaft as the centrifugal activation assembly functions. Then, consider forcing that assembly BACKWARDS..prying the spring assembly OPEN by twisting the shaft and the forces applied that way.
Not the same thing, 'eh?
With the governor shaft disconnected from the KIPS, the cylinder components should move easily using your fingers.
Can you 'open' the spring assembly with your fingers?
OK..given that you have vise-grips for fingers..maybe you can. BUT, the forces required are NOT the same.
Amen.
That means now..not at some more convenient other time.
Your chances of completely destroying the engine at this point are very good.
terminatr
I broke KIPS
Post by terminatr »
Well. It's not going to happen "now". I ordered the pin from Rocky Mtn last night. Just checked my order, and it says the pin is on backorder until Sept !!! Somebody hoarding these pins?
2001 KDX220
Re: I broke KIPS
There are other parts providers.
Try RonAyers. You would have to call to find out if they can get it. I'm sure their website does not list current availability. They order from their supplier as they need parts to ship.
800-888-3084
SKU QTY Your Price List Price Total Price
185196 LEVER-COMP,GOVERNOR (13236-1260) X $5.70 (List $8.26) $5.70
terminatr
I broke KIPS
Post by terminatr »
I called the local Kaw dealer. Guy said have it here by the end of the week. But the catch is
that it's $10 plus tax. What the heck! MSRP is only 8.26. Internet is selling them for $6. I buy
stuff from dealer seldom. But everytime I do, they price gauge me over MSRP.
So do walk-in customers get screwed or something? Do mechanics get special pricing or what?
As much as I prefer to support the local economy, sometimes I wish the internet competition crushes them to death.
2001 KDX220
Re: I broke KIPS
I'll pay maybe 20% more to buy something locally. By the time I figure shipping..and what it costs the local outfit to simply ORDER the part (let alone stock/inventory the part if they do that)..the extra is worth it just to have the local outfit stay open.
Or...you could wait 'til September for RMMC to get it....
The price difference is going to seem insignificant if that pin lets loose and you blow holes in your cases.
Not trying to make a big deal out of nothing. It's happened before. And not just once or twice.
amstel78
Re: I broke KIPS
Post by amstel78 »
Out of curiosity, what is that pin made off? If you turn the actuator a little by hand just to ensure it's not broken and there's still tension, is that enough to damage it?
Sent from my SGH-T989 using Tapatalk 2
terminatr
I broke KIPS
Post by terminatr »
It's made out of steel. Maybe here's an opportunity for industrious enterprenur to capitalize
by making a super strong pin that never will break even if you turn the advancer
shaft unsupported.
2001 KDX220
terminatr
I broke KIPS
Post by terminatr »
Well, I still hate dealership. Went there to pay for the part. When they try to order it
on the computer, the part is now shown out-of-stock. So they can't guarantee it getting here
by this week, or even next week. That's great. After driving 45 minutes in my lunch hour...
nothing.
2001 KDX220
Re: I broke KIPS
amstel78 wrote:Out of curiosity, what is that pin made off?
As noted: It's steel.
The strength of the material is not the issue. It's the leverage/force applied. The pin itself does not generally break/bend, but the bracket that attaches the pin to the governor rod gets tweaked.
amstel78 wrote:If you turn the actuator a little by hand just to ensure it's not broken and there's still tension, is that enough to damage it?
No.
But....
Ensuring it's not broken doesn't tell you that it is not bent. If it is bent, you will still feel tension..but not KNOW if the pin is bent...or not. IF the assembly is bent, it is likely fractured, and it will likely break. Eventually.
Also, there is a HUGE difference between turning it 'a little' by hand to feel if it's 'there' and turning it far enough to move it OUT of place (as was indicated by the OP).
Consider (I don't know this..I'm making up the actual numbers. BUT...the basics fit the situation): The centrifugal assembly will 'open' 3/8". The distance from the pin to the shaft is 1/2". Under normal operation, the opening being less than the radius of proscribed movement of the governor rod/pin is of no consequence. It ensures the rod stays IN the slot (and properly oriented..not over-center) to the spring assembly opening as the spring assembly moves the governor rod.
BUT...turn the ROD and force the spring assy full open..and you still have 1/8" of radius to travel. To KEEP turning it (not much force..you 'only' have a liddle wrench on the rod flats..no big deal... :naughty: ) farther, FORCES the pin to bend. What seems like 'no big deal' force-wise to you will easily bend the piece that holds the actuating pin to the governor rod.
No reason the dealer could not have checked the status of the part (if ordering) or confirmed they actually had one on hand (if they had said they did). If RMMC says it's BO 'til September..that's a Big Red Flag sayin' availability through someone else MUST be verified.
Repeat: Do email/phone Ayers and verify that THEY can get it...if you go that route.
Good luck!
amstel78
Re: I broke KIPS
Post by amstel78 »
Thanks for the detailed reply. I only asked about turning it gently by hand is because I did that earlier this morning after tightening the reverse nut. I of course supported the shaft so no real torque was applied to the pin. After tightening the nut, I twisted the lever slightly with my fingers to ensure tightness. As such, the shaft moved a little and I could feel spring tension. I did not force it past that.
Just wanted to make sure I didn't damage anything. From what I've read, I'd imagine this pin to be so delicate that I'm paranoid now.
Been thanked: 12 times
Re: I broke KIPS
It's not all that delicate. The issue comes when trying to loosen or tighten the nut without supporting the shaft.
