my 96 long term project
Posted: 05:07 pm Jul 23 2012
Hey guys
i've decided to keep an online diary, i mean, build thread, on my recently aquired 96 KDX 200 project bike
rather then having a dozen different posts about it everytime i have a question im just going to keep it all in here
i found this bike for 400 dollars on craigslist
the story went the first owner owed the guy i bought it from some money and he gave him the bike to settle the bill
it was recently rebuild and had been sitting for 2 years
now, it wouldnt start, thought if you spayed started fluid in it it would run for a few seconds
i was hoping the bike was fine when it last changed owners and had sat with premix in the carb for the last 2 years and that was the problem
easy fix, i figured, turn around and sell it for double what i paid for it
well, no such luck
when i got it home and started stripping some parts off it i noticed there were a few things worng with the bike
so far i have noticed the following flaws:
inner clutch cover broken
KIPS actuator governor broken
piston shot
cylinder in need of replating
intake booth broken
rear brake reservoir mounting tab broken
rear master cylinder gaurd missing
rear tire woudnt hold air
one rear spoke missing
no headlight/numberplate
i have bought a used inner clutch cover
a new kips actuator governor
new intake booth
used rear master cylinder gaurd
new rear spoke
and the acompanying gaskets
the gaskets and governor should be in tomorrow so then i will put the inner and out clutch covers back together
i have allready played with the piston and i got the rings to free up again
once all that is put back together i will put the engine back in the frame and see if it might run (though i doubt it) with the louzy piston and cilynder)
money for a new top end probably wont come around untill Christmass
this is me and the boy when we went to pick the bike up
the damaged inner clutch cover
the damaged governor
the damaged piston
to make matter even worse i took a nasty spill on my daily driver KDX and i had to scavenge some front end parts off this project bike to make up for the damage, so now it is also missing the handlebars and the clutch perch
ill post a shot of the bike as it sits later to show the backwards progress ive made
i did manage to stop by my local car tire guys and they had a look at the rear inner
they installed a new valve and she is good as now, as soon as i get the new spoke installed i will put the rear tire back on :)
(and finally a list of links to all the posts related to this rebuild)
http://kdxrider.net/forums/viewtopic.ph ... 20#p117620
http://kdxrider.net/forums/viewtopic.ph ... 07#p117807
http://kdxrider.net/forums/viewtopic.ph ... 14#p117814
http://kdxrider.net/forums/viewtopic.ph ... 00#p118400
http://kdxrider.net/forums/viewtopic.ph ... 89#p118489
well, no such luck
piston shot
intake booth broken
new intake booth
new rear spoke
the damaged piston
