I rebuilt my 98 KDX 200.
It idles fine
Low end feels ok
As soon as the power band starts to kick engine runs like crap.
It wont rev on out and power sucks
Please help me trouble shoot this.
Quick reference edits (below is info added after my original post):
I update here to save reading all posts. So, use this as a quick reference. But, if you read the entire post there are many great tips if your problem sounds like mine.
- my major problem was the power valves and jetting issues, but the major thing was the power valves. They were in backwards..... Thanks to the backwards manual. *note* the sub valve with the groove near the top of the shaft actually goes on the right along with the sub valve actuating rod that has the o-ring on it. they both go together on the right side as if your were sitting on the bike. (The manual actually says the sub valve with the groove goes on the left, that is wrong).
- Do not chemical dip the kdx carb. They have a hidden o ring on the jet block which will loose its seal if you dip. I found several others which claimed same problem as me. Carb ran like it was rich and they could not jet it away.
- found the jet block o-ring from http://www.sudco.com for $5.00. they have a minimum order of $25.00 or a $5.00 handling fee. Part number is 021-532. BTW it is like 4 seals all conjoined as one thing so that one part will cover you.
- for me, in tennessee, after a rebuild involving boreing and replating, rejetting my carb solved the rest of my problems. I am running 45/155 with the needle clip on the second from top groove.
- The posts here were very helpful and ultimately the path to a solution and a ride-able bike.
