Still having idle problems
Trails Boy
Post by Trails Boy »
I was told on one of my later posts that part of my idle problem could be a bad seal on the left side of the crank case? Would that be the clutch cover? Totally confused please help.
Also I just got done with the rebuild and can actually pull a wheelie for once! :lol:
Has thanked: 5 times
When anyone says left/right side they are talking about as you sit on the bike to your left or to your right. The bad seal they are probably talking about is the left side (shifter side) crank seal. It is a common problem on older bikes as the seals harden with age and wear out.
Trails Boy
Image Okay is the cover here with Kawasaki on it considered the left side crank case then? So that seal?
Has thanked: 6 times
Yes, that is where he was talking about. That is the left side. If you take that cover off and it has a pool of oil (not water), then you most likely have a problem.
Trails Boy
Re: Still having idle problems
Okay cool. Well why would there be water? Mines air cooled.
david
Country: UNITED STATES
Post by david »
From deep water crossings.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Trails Boy
Oh okay. So I should take that off and have a look then?
Yes. If there is premix or oil residue then the seal is leaking.
Trails Boy
Well I know this doesn't exactly mean there's not a air leak but I was able to adjust the lower adjustment on the cable and get it to idle! :D
Try it out and see what happens. If the idle seems to be better then ride it. If your not sure keep an eye on your plug and see if it goes white or stays a fairly consistent color.
Trails Boy
I took it for a ride and it does great! It bobbles a little when I go from low speed to mid speed... Do I need to adjust the needle?
