idle adjustment screw vs air screw
Posted: 09:23 am Jun 05 2012
by eroknroll
Can someone please explain the virtues of the idle adjustment screw, and how to properly adjust it? I am all square on setting the air screw, but where does the idle adjustment screw fit in getting the bike running properly. Thanks in advance.
Posted: 11:08 am Jun 05 2012
by KarlP
The idle adjustment screw sets how low the slide will fall in the bore of the carb.
You may have to go back and forth a bit from air screw to idle speed screw to get a good idle, but the idle screw should not be used to compensate for a bad pilot jet choice
Sometimes the end that contacts the slide gets all buggered up.
