new member and first post
i am in great britian,uk,and recently purchased a 2001 kdx220r,which i was told is a canadian import,currently doing some work on it as i want to get it registered over here,and also get a full mot.
first question i have is about the regulator,i have tested it (as described in the manual) but i cant get a ohm reading,may be my multimeter? (the manual says some might not work correctly?) the front and rear light work ok,just wondering if there was another way of testing it to make sure its ok?
second question,i am currently wiring some brake lights up (hydraulic switch front and rear,bay15d 3 wire bulb holder,and matching led bulbs)
just wondering where to take my live feed from? i know some use the tail light feed,but i want a constant feed so they work without having to have full lights on.
ive taken a nosey at a couple of wiring diagrams where it looks like the feed was taken from the brown wire of the regulator?
i dont seem to be getting any voltage from this wire,hence the first question.
any help on the above will be very much appreciated,and i am sure they wont be the last questions!
best regards
john
