Fumbling my way through a hybrid build
Faint333
Post by Faint333 »
I might as well post my progress (and lack of at times) of this hybrid build project. I started with my 2002 KX 125 which I was riding up until the day I sold the motor. I then bought a 2003 KDX 220R that needed a little TLC and maintenance.
Poor KX doesn't know it's about to be torn apart and will never be the same.
The KDX after washing it up getting ready to be torn down.
Closeup of the KDX motor, lots of oil under the case.
Woods pipe is in great shape, just dirty.
Faint333
How to fumble your way through a hybrid build
Post by Faint333 »
Tearing down the KDX, quick and painless
Cleaned up the motor a little bit and took a shot with it out of the bike.
Found a nice JB weld spot on the clutch cover... somehow I didn't notice this earlier. Haha
Culprit of much leakage!
I hacksawed the rear headstay off..
and then grinded the rest down to this result.
Now the carb and head are on their way to RB Designs! :rock:
Faint333
Post by Faint333 »
Here is a side by side comparison of my kdx and kx air boots.
I can see why people say the KX boot basically eats the KDX carb!
I made some stencils and cut out a test piece of plastic, if it works well when all is together I will probably go with aluminum.
KDX air boot mated to KX air box with the plastic bracket. I just hope it clears the rear shock...
Tedh98
Post by Tedh98 »
The air box/boot is looking good. Do you have the KDX engine in the KX frame to get the boot positioned?
The air box is the single item I spent the most time messing around with. I know it didn't really work out this way, but it felt like I spent 1/2 my time on the air box and the other 1/2 doing everything else.
Faint333
Post by Faint333 »
The motor isn't in yet, hopefully this weekend or soon after. I'll probably have to make adjustments to the air box bracket but that's fine. I cut a bunch of mounts and the frame loops off the kdx frame with my sawzall. If I can re use them that's one less thing to do.
Also cut the swing arm. I was originally going to match it to the size of the KDX swing arm but figured I'd go with the 9mm each side (to match KDX it would be more than 9mm.)
Faint333
Post by Faint333 »
Right now I'm wishing I got the measurement of the KX rear mount to find the difference of the KDX rear mount, and divide by two to get the rough bushing size. Did most of you guys just take off small increments at a time and test fit to get the bushing size?
doctord23
Post by doctord23 »
Nice job on the airbox boot mount. I may have to try that myself. Be sure and show us a picture when you get it mounted.
I personally just used the KX boot on mine. Here's how:
I had an old airbox off of an 87 KDX. I cut the end off where is slides over the carb. I cut it just long enough that the stop was left so it only slides onto the carb so far.
I could do the same thing with the KDX boot, but why ruin it.
The piece I cut fits tight on the KDX carb and and is just the right thickness to allow the KX boot to slide over it.
It is a bit of a pain to get the KX boot on as you have to pull the subframe off and get the boot in position and clamped down before you tighten down the subframe, but it works.
The KX boot is a little compressed, but still has plenty of airflow. A lot more than the KDX airbox anyway.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
Faint333 wrote:Right now I'm wishing I got the measurement of the KX rear mount to find the difference of the KDX rear mount, and divide by two to get the rough bushing size. Did most of you guys just take off small increments at a time and test fit to get the bushing size?
yup and then slowly filled away the excess till it was a perfect fit.
doctord23
Post by doctord23 »
I did one a couple of weeks ago and it is almost exactly 18mm of difference by taking the difference between the two engine case widths; 9mm each side.
I then used a piece of masking tape on the sleeves and got them close with a grinder, then used a flat stone to get them level. It was a snug fit when I was done.
The good news is that you can always buy new sleeves if something goes wrong as they are the critical part.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
mine was a bit offet so I transferred it to the new swingarm. measure twice, cut once :wink:
Tedh98
Post by Tedh98 »
Before you start cutting and assume you should take off equal amounts from each bushing, take some measurements or set-up the swingarm so it is in line with the sprocket. You can tell where the chain ran on the slider before, so make sure that lines up with the sprocket. Then see how much you need to take off on each side.
While many have been able to split the difference, mine wasn't exactly 1/2 on each side.
I started cutting down one bushing until the swingarm was in the proper position. Then I started taking off very small amounts on the other bushing until I got the right fit.
As was mentioned before, the swingarm isn't the critical part, the bushings are. Good news is that if you make a mistake, replacement bushings aren't that expensive.
Faint333
Post by Faint333 »
I got my RB carb and head today!
Tomorrow I'll be getting the motor in the frame. I'm just going to do a cheapie spray can job after the mounts are good. I'm thinking of doing a textured blackrustoleum truck bed liner. Any thoughts on that on if it seems like a decent idea or not?
Only downside I can think of is if my riding pants get caught on the texture.
Faint333
Post by Faint333 »
For those of you who want to see a side by side of a stock head vs RB head.
Stock freshly taken off the KDX.
And here is the head back from RB!
Faint333
Post by Faint333 »
I'm in dire need for good tips on bending : denting fmf woods pipe. Everything is tacked in, similar to hrdrokn but he has way more skills.
Part of my solution was to double up gaskets for exhaust for added clearance but with that only one rubber gasket is set in cyl.
Faint333
Post by Faint333 »
Got the swing arm mounted and test fit the air boot to carb. I didn't have the shock with me to see the clearance but it looks like it should be fine.
Picture of the motor "floating" between headstay and swing arm.
This is why the motor won't move forward farther, a small part on the bottom of the case hits the frame rail
Before Grinding.
After Grinding.
Now the motor can be rotated forward a bit more, the lower mount is resting on the frame in the picture.
My lower mounts... copied Hrdrokn! Welded a washer onto the end of a 1" diameter steel tube.
Here they are cut, one side must be shaved down a bit to clear the case.
Got everything tacked up!
Faint333
Post by Faint333 »
Mounted the pipe, welded a mount farther back than the KX one so I could use the stock bushing hanger thing. No clearance issues but like I said I'm using two metal gaskets in the cylinder, I may have to use some silicone if it's leaky.
I cut off the pipe to my KX125 turbine core 2 and mounted it up.
Then I took the pipe from the KDX FMF pipe I had laying around and cut/rotated it to fit and tacked/welded.
The bike is actually coming together!
Oh, I also cut off the lower mount off the Gnarly pipe and welded a mount onto the front of the frame rail above the pipe. I'll get a picture up in a bit.
dfeckel
Post by dfeckel »
Looking good!
David Eckel
Faint333
Post by Faint333 »
Thanks!
The frame is now at the powder coaters getting some silver color the guy used on a harley tank. I'm not very picky and it looked close enough to what I'm looking for. $250 though...
Opened up the inner clutch cover and found the broken kips part. The damn 13236-1260, it's tweaked out bad. I'm glad I didn't run the bike much. :shock:
Been thanked: 2 times
Looking great so far!
Faint333
Post by Faint333 »
Thanks Nick! I can't wait to ride it, hopefully it will be ready for this weekend! :rock:
I was bored today and had nothing to work on (this wait is brutal, I haven't gone riding in a few weeks!) so I painted the caliper guards with the truck bed liner by rustoleum. They came out O.K.
I wonder how long the paint will last, if they end up looking like crap after a few rides i'll just strip it off with acetone...
