pump or premix
pump or premix
my bike has been running on premix since i bought it 2 weeks ago but is also fitted with a seperate pump so my question is which is best pump or premix?. does the pump lube anything else or can bike be run safely without it and completely removed? im asking because bike is going in for complete rebuld tomorrow so any help id be very gratefull for
bike has been running at 36-1 does that sound right
- scheckaet
pump or premix
As far as I know, the pump is for oil premix only.
You need to make sure the oil pump is disabled if you're going to go the premix route.
if you're going to go back to using the pump you must make sure it really works and is tuned properly before using it.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
pump or premix
the bike is allready running premix as i bought it 2 weeks ago and would like to keep on premix but keep reading well they also lube the main bearing? how is the pump disabled but sure the repair shop should know this?. as long as it wouldnt damage anything would rather run premix. many thanks for your helpscheckaet wrote:As far as I know, the pump is for oil premix only.
pump or premix
Feel free to stick to premix. 36 to 1 sounds good to me. IF!! the oil pump ever went out, you would be screwed. Just make sure it is disabled, blocked off, etc.
- Jaguar
- Country: Ecuador
Re: pump or premix
On my Suzuki street 2 stroke I use premix and I haven't done anything to "block it off". I don't think you have to.
Read about engine oils and premix ratios here: www.dragonfly75.com/moto/oil.html
