Page 1 of 2
91 fork
Posted: 07:01 am Apr 07 2012
by dnovack
does anyone kno where i can find a thread or site that has someone who made fork guards from pvc? i want to add protection to the forks but just dont know how to mount them to the fork tube. putting kx forks on are out of the question dont have the money for that and didnt like the rubber boots on the forks from oem.
Posted: 03:34 pm Apr 07 2012
by Julien D
You could get one of those number plates of the older RM125/250 that had upper fork guards built in.
http://www.ebay.com/itm/RM125-SUZUKI-19 ... 79&vxp=mtr
Like that. Of course, you sacrifice your headlight.
Posted: 06:48 pm Apr 07 2012
by dnovack
Yea id like to keep the light.
Posted: 07:50 pm Apr 07 2012
by SS109
Improvise, adapt, and overcome!
Sorry, I don't know the website your looking for but you should be able to figure it out fairly easy.
Posted: 08:43 pm Apr 07 2012
by dnovack
I was looking at it tonite its just the question of how to mount them to the fork tube.
Posted: 10:18 pm Apr 07 2012
by SS109
Large zip ties or hose clamps.
Posted: 05:32 am Apr 08 2012
by dnovack
Yea but that to me looks a tad bit ugly. Im trying to think of a clamp to make it look clean.
Posted: 09:33 am Apr 08 2012
by dnovack
i think i found a way to do it. i was reading a thread last night about a guy who took pvc slit the back of it and snapped it on the fork tube. think im going to try it. need to measure the fork tube and get myself some pipe.
Posted: 07:59 pm Apr 08 2012
by Julien D
dnovack wrote:i think i found a way to do it. i was reading a thread last night about a guy who took pvc slit the back of it and snapped it on the fork tube. think im going to try it. need to measure the fork tube and get myself some pipe.
Lets think about this. PVC snapped over the fork tube... You looking to eliminate your suspension travel? I can't picture how that would work. It has to be secured to the lower fork or the triples, not on the inner fork tube.
Posted: 12:27 am Apr 09 2012
by kingmoochr
i was assuming it was snapped onto the outer tube...i would hope no one making their own parts would think snapping onto the inner tube would work :lol:
Posted: 04:44 am Apr 09 2012
by dnovack
Yea the outer fork tube. Putting it on the inner would be silly. It sounds like it will work in logic.
Posted: 09:04 am Apr 09 2012
by Julien D
What would you secure it with? Epoxy or something? Might work. If you do it, take pics!
Posted: 04:36 pm Apr 09 2012
by dnovack
ok will do.
Posted: 04:50 pm Apr 09 2012
by rbates9
The PVC will end up being pretty short after you take out the compression distance. If you already have the stock boots off than go jump it or try some other way to FULLY compress the forks and see how much distance you have from the top of the lower tube to the triple clamp.
Have you considered seal savers?
Posted: 05:13 am Apr 10 2012
by dnovack
Seal savers?
Posted: 06:34 am Apr 10 2012
by Julien D
Posted: 02:11 pm Apr 12 2012
by dfeckel
If he uses a coping saw to contour the upper portion of the pvc pipe into a simple shield, but keep the bottom 2 inches pipe-shaped with a slit, then the bottom two inches would snap around the lower fork tube and the shield would be positioned in front of the upper tube. It still might want to bash into the side of the headlight, so some trial and error would be necessary to get the shield shape right.
Posted: 05:23 pm Apr 12 2012
by dnovack
thats kinda what i had in mind. im going to get the bike running this weekend and then on to this little idea.
Posted: 06:35 pm Apr 15 2012
by dnovack
Well i got her running like a rape date. Now time for the odds and ends then off to open it up and do sum carb ajustments
Posted: 02:15 pm Apr 16 2012
by Mr. Wibbens
protecting something that does not need protecting
$#@& you n00bs kill me :lol:
