kdx200 shock
raybe
kdx200 shock
hi everyone im new here,i got a kdx200 last summer,and stripped it down,to rebuild,ive put cagiva mito 125 wheels on it,and done lots of other stuff,is only going on the road,what i want to know is,has anyone fitted a different rear shock,??? maybe a ktm or something ,even if it will make the bike a little lower,i dont mind,shock standard is about 440 eye to eye,maybe a 420 or anything that has worked on road or off,,many thanks.
- gsa102
raybe
hi well first off the standard shock i have,needs service,and i think its a little to high,,so a little shorter is prob better for me,the bike is now lower with the wheels,but it wont be jumping or anything,,so just firm and good for road i guess,im also not putting it on any tracks,,,so just road use fun bike.
i have seen some ktm duke ones,that are a little shorter than standard,looks like might fit,also drz but there longer,than standard,,so yeh if a suzuki will fit ok,, lower links will prob be best,???..any info where i can get some links,many thanks.
- kawagumby
kdx200 shock
Just for the info...if you want a shorter shock, racetech sells plastic spacers that can be placed on the shock shaft within the shock body. The more spacers, the shorter the travel. It would be easy to make your own aluminum spacers or plastic too. When you get a shock serviced, they (or you, if you're into diy) can easily place the spacer(s) inside while doing the work. That way you'll have a shortened shock that will fit properly, doesn't cost a lot, and can be set back to the original length with a simple tear-down.
raybe
