Motor oil as fork oil
JoKDX220r
Post by JoKDX220r »
Hi all,
ihatefalling wrote:Yea forks will have to come off. No biggie. Use 10 wt oil if you have ths cash. If not use atf..... its 7.5 wt.
I wonder if 5w30 or 10w30 would work fine as fork/shock oil ?
Anyone already try it ?
thanks!
tirebiter
Post by tirebiter »
No, it wont. Motor oil foams up too much.
You can use ATF though, Mobil 1 synthetic ATF is around 7.5 wt.
If I can't do it, I'm sure someone else can!
david
Country: UNITED STATES
Post by david »
I have used power steering fluid, too as it is a hydraulic fluid and has an anti-foaming agent in it. It's what I had in the garage.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
hockeyboysomers
Post by hockeyboysomers »
5/30 or even 0w mobil 1 is too thick. I tested the viscocity between Mobil 1 and 5wt Bel Ray fork oil, and there is no comparison. I used 2 small dixe cups and poked a pin hole trough the bottom of each cup. I filled each cup with oil and timed how long it took each cup to drain. By the time the fork oil had drained the Mobil 1 0w oil still had 3/4 of a cup remaining. At that point I knew even the thinnest motor oil would not work as fork oil.
JoKDX220r
Post by JoKDX220r »
Thanks for the infos !!
ihatefalling
Post by ihatefalling »
When I bought my DRZ the forks were really stiff. Went to change the fluid and the dood had put motor oil in there. Mo better after putting ATF in there . .
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
