NGK 8, or 9? Also, a couple other q's...
Posted: 06:44 pm Mar 17 2012
Hi all. I finally got my '90 KDX going with new top end rebuild including new nikasil. It's really crisp and tight. I noticed in the manual that it says to run the NGK B9es. I always thought you were supposed to run b8es? I put a 9 in for break-in for a cooler combustion. Should I leave the 9 in? The UK models call for BR9es, is it ok to run the br in the American models? The r means resistor, right?
Also, at operating temp the bike with idle low after a short rev, but it'll raise a bit after 3-5 secs. Nothing real bad, barely noticeable. Maybe I'm just being paranoid. It runs great and has nice throttle response the whole way around. I checked for air leaks with some quick start. I even checked the flywheel side crank seal. No change in idle. Would float height have anything to do with that? Also, I'm still running the 48 pilot jet. Could that be the calpret?
Oh, one more thing. I'm missing the coolent reserve tank. Is it safe to run it without that, or should I be grabbing a new one. Will it suck air through the coolant system without the reserve tank?
Sorry for all the Q's in one post. Just trying to kill 2 birds with one stone. Thanx.
