E series piston ring tolerance?
Does anyone know what the piston ring tolerance is suppose to be on an E series (89-94) 200? Just got my cylinder back. I put the rings in the cylinder to see how tight they were. They're pretty tight looking. Like, maybe less than 0.5 mm. Is that normal? I haven't measured yet, just eye balling. Actually, it almost seems like one may be tighter
. They are std bore Kawi oem rings. Both have a faint small R on each ring. Also, I'm sure this is no biggy, one of those R's is from a different stencil. Wierd?
KDX ALL THE WAY!
Great. Sounds like it's in spec. Glad you can help Juliend. You're right about getting a service manual. That would certainly have answered about 85% of my posted questions. My local shop said that I can borrow their manual cause it very rarely ever gets used anyway. I definitely need it for synchronizing my KIPS. Maybe I'll photo-copy it. Lol. Just kidding, I'll order one.
Thanx.
Thanx.
KDX ALL THE WAY!
- Has thanked: 5 times
- Been thanked: 12 times
NP man.
That link at the top left of this page takes you to the cyclepedia manual for 89-94 models. The one year subscription is a great deal for cheaper than a factory manual. The color pictures are great, and you can just print out what bits you need when you need them. Before your year is up, make sure you print the whole thing. It should be all you'll ever need as far as a shop manual goes.
