KLX 300 forks
Posted: 04:58 pm Feb 07 2012
by asmed12345
Could I swap stock KDX forks with KLX 300 forks with little to no effort or will there be a tough time geting them on?
Also, will these work as good on trails as other types?
Posted: 06:07 pm Feb 07 2012
by Slick_Nick
Direct swap. I love mine.
Posted: 10:44 pm Mar 24 2012
by lambe67
>|QBB<[/url]
Slick_Nick wrote:Direct swap. I love mine.
By direct fit, is that swapping stems out, wheels brakes calipers, etc. or just need the triples clamps and forks and everything else will fit. thanks
Posted: 05:42 am Mar 25 2012
by Slick_Nick
Direct swap means just that. Kdx forks come off, klx ones go on. Done.
Posted: 08:02 am Mar 25 2012
by diymirage
Slick_Nick wrote:Direct swap means just that. Kdx forks come off, klx ones go on. Done.
does this go for all years and displacement KLXs?
and at the risk of being redundant, you are running your stock KDX wheel and axle right ?
Posted: 08:10 pm Mar 25 2012
by 4vman1
Yes, just the forks and clamps are all you need for the swap. If you can score some of the stock fork guards that come on the klx like slick nick did, that would be best. Otherwise, you'll have to make kx guards fit and mickey mouse the routing on either the brake line or odo cable. The stock kdx brake caliper, wheel and axle fit the klx fork. They're just as plush as stock kdx forks without getting stuck in all the ruts.
Posted: 09:53 am Mar 26 2012
by Slick_Nick
The only thing you'll have to do is make your own routing for the KDX brake line. The KLX caliper has the hardlinethat comes under th fork, then up. Lots of KLX guys change them out for this reason, because one rock hits there, and your out a front brake. It's very easy to make the stock KDX line work. You'll see wher it needs to go once you bolt the caliper on.
Other than that, yes the stock KDX wheel, axle, odo, brake, etc all fits perfectly. You'll only need the KLX300 forks (mine are 97 but all 300's had the same forks with the exception of tube color) If the forks don't come with guards, late 90's KX125 guards are a direct fit.
You will need to respring them for your weight, unless you're the size of a horse jockey.
Posted: 09:54 am Mar 26 2012
by turtle
4vman1 wrote:Yes, just the forks and clamps are all you need for the swap. If you can score some of the stock fork guards that come on the klx like slick nick did, that would be best. Otherwise, you'll have to make kx guards fit and mickey mouse the routing on either the brake line or odo cable. The stock kdx brake caliper, wheel and axle fit the klx fork. They're just as plush as stock kdx forks without getting stuck in all the ruts.
Good info. Wish I would have known that before. How much are these forks/clamps going for? I'm just asking for the heck of it because I already have invested in KX forks, and those are currently with a tuner setting them up for trail riding. I just like how easy this sounds. SlickNick, no additional fiddling required on valving or anything?
Edit to add: I think you just answered this.
Posted: 12:38 pm Mar 26 2012
by Slick_Nick
I paid $150 for mine, plus $100 for new springs.
Posted: 03:26 pm Mar 26 2012
by lambe67
Thank u for quick reply I just got a set of 2005 forks on eBay for 150 and a triple clamp for 60 so not to bad
KLX 300 forks
Posted: 01:10 am May 03 2012
by tacohank
slick nick, so the stock klx 300 forks are sprund heavy from the factory?
KLX 300 forks
Posted: 05:30 am May 03 2012
by Slick_Nick
No. Sprung WAY too light.
KLX 300 forks
Posted: 12:16 pm May 03 2012
by tacohank
ohh got it, well i weigh 135 lbs without gear on. do you think i would need to respring them with heavier springs?
KLX 300 forks
Posted: 03:14 pm May 03 2012
by Slick_Nick
Then no. They are set up for a 140lb rider stock.
